Dormobile rear seat stowing straps
Gday. Can anyone please post some pictures of the 2nd row seat stowing straps? Where they anchor to and what they look like?
Glen
Glen
Re: Dormobile rear seat stowing straps
Hi Glen and welcome to the forum, the rear seat straps were made of canvas and had a simple buckle on them . Mine were a bit worse for wear and I removed them and replaced them with a more modern plastic type as fitted to schoolbags
I think I might have kept the originals, so when I remember I'll try and find them and take a pic. This pic shows the strap (at the front of the curtain )
- seatsideways.jpg (18.88 KiB) Viewed 13648 times
Thanks Jerryd. I'd definitely appreciate some pictures as the only ones I can find are grainy and hard to make out. From what I can tell the end of the strap slipped behind the plastic trim around the hole in the roof and was presumably anchored by a screw.
My Dormobile was missing these straps when it came to me but I can see they'd be quite handy to have!
Glen
Glen
Hi Glen,
Is this what you are looking for?
It is held on by two screws.
Regards,
Regards,
That's perfect Ian thank you! I can see one screw in the picture, where does the other go?
Glen
Glen
Glen The other one is a mirror of that one. There is only one screw per side.
HTH
Alex
HTH
Alex
Both my straps have two screws. Its a 1962 so your mileage may vary.
My Straps have two screw, cross corner with an alloy plate over the strap. My Dormobile has this type of buckle on white straps originally. But it now has green straps as I picked up a load of them at a Land Rover show.
http://www.ebay.co.uk/itm/231691913563? ... EBIDX%3AIT
Thanks all! Can anyone post a picture of the straps installed please?
Glen
Glen
Hi Glen,
Here is a picture of where they attach on the 'C' post, (interior trim not currently fitted). Note; the webbing on mine is a replacement as the originals finally split after many years and the black nylon strap was just a convenient substitute. I still have the originals - somewhere ?
