Dormobile rear seat stowing straps
Litelandy
Post by Litelandy » Fri Feb 19, 2016 2:30 am
Gday. Can anyone please post some pictures of the 2nd row seat stowing straps? Where they anchor to and what they look like?
Glen
Re: Dormobile rear seat stowing straps
Post by jerryd » Fri Feb 19, 2016 11:12 am
Hi Glen and welcome to the forum, the rear seat straps were made of canvas and had a simple buckle on them . Mine were a bit worse for wear and I removed them and replaced them with a more modern plastic type as fitted to schoolbags :whistle:
I think I might have kept the originals, so when I remember I'll try and find them and take a pic. This pic shows the strap (at the front of the curtain )
Litelandy
Post by Litelandy » Fri Feb 19, 2016 12:27 pm
Thanks Jerryd. I'd definitely appreciate some pictures as the only ones I can find are grainy and hard to make out. From what I can tell the end of the strap slipped behind the plastic trim around the hole in the roof and was presumably anchored by a screw.
My Dormobile was missing these straps when it came to me but I can see they'd be quite handy to have!
Glen
Post by Ian » Sun Feb 28, 2016 10:08 pm
Hi Glen,
Is this what you are looking for?
It is held on by two screws.
Regards,
Litelandy
Post by Litelandy » Sat Mar 05, 2016 3:08 am
That's perfect Ian thank you! I can see one screw in the picture, where does the other go?
Glen
Post by AlexB » Sun Mar 06, 2016 5:50 pm
Glen The other one is a mirror of that one. There is only one screw per side.
HTH
Alex
Post by Ian » Sun Mar 06, 2016 9:23 pm
Both my straps have two screws. Its a 1962 so your mileage may vary.
Post by Jabbawocky » Mon Mar 07, 2016 12:13 am
My Straps have two screw, cross corner with an alloy plate over the strap. My Dormobile has this type of buckle on white straps originally. But it now has green straps as I picked up a load of them at a Land Rover show.
http://www.ebay.co.uk/itm/231691913563? ... EBIDX%3AIT
Litelandy
Post by Litelandy » Mon Mar 07, 2016 2:18 pm
Thanks all! Can anyone post a picture of the straps installed please?
Glen
Post by Dormy » Tue Mar 08, 2016 5:54 pm
Hi Glen,
Here is a picture of where they attach on the 'C' post, (interior trim not currently fitted). Note; the webbing on mine is a replacement as the originals finally split after many years and the black nylon strap was just a convenient substitute. I still have the originals - somewhere ?
Seat Strap
Seat Strap
